1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | lilrobo,they do make a special tool for doing the procedure,if you can't do it with a screwdriver and wrench.Type this into ebay search and you will see it. Engine Rocker Arm Adjustment Tool Zim Mfg co
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Get one adjusted while engine is running, then if you want, shut it off and adjust the rest the same amount. Just be sure each one is off the lobe of the cam.
The ticking in the morning could be one slightly loose still, you could give all of them a 1/4 turn more, or next cold morning, pull the cover and look for the loose one only and tighten it down. One lifter may be worn or machined with more clearance.
Isn't this fun?
Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | lilrobo,they do make a special tool for doing the procedure,if you can't do it with a screwdriver and wrench.Type this into ebay search and you will see it. Engine Rocker Arm Adjustment Tool Zim Mfg co Tim Here are a few valve adjustment tools that Tim might be referring to - the ZIM and New Britain tools might be the same; and, they are more helpful than the Snap-On/Proto tools. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i am real close now , its just when i do a cold start i hear them ,, i will drive it a little and re adjust them ,, 1 other thing right now when hot driving at 180 to 170 temp my oil pressure is 40+ driving ,, but at light it drops to 25 is that ok?? got me worried but as soon i get on the gas it jumps to 40 again ,, the idle is about 500 to 700 rpm just guessing no way to tell ,,
thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It is normal for the oil pressure to drop off some at idle. It sounds like your just fine. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | great iam just a little gun shy after all i been through ,, this is were you dont need a gauge to look at all the time lol
thanks guys
now i can get back to my windows , replacing channels and fuzzys
