3 members (3B, 55shaker, Gdads51), 103 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
#905463 12/22/2012 1:43 PM
Hello All,
Can anyone tell me what size bolt w/tread the mounting bolts are for the T5?
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Bread #905467 12/22/2012 2:02 PM
Use your original bolts,the threads are in the bellhousing not the t-5.You will have to drill out the t-5 mounting holes(4) to 1/2".
Tim
1951 3100 Chevrolet
Bowtietim,
My apologies, I wasn't very clear on what I was asking. I am asking for the bolts that bolt up to the crossmember mounting pad. I do have the everything you mention completed. clutch housing to trans
Bread
Bread #905505 12/22/2012 5:05 PM
If your talking about the transmission mount bolts(2)I know the head is 15mm.I'm not sure of the thread size.
Tim
1951 3100 Chevrolet
Bowtietim,
Thanks for the help.
The third time to the Auto Zone did the trick.
Dorman
980-530
M10-1.50
x 30mm
HEX FLANGED CAP SCREWS
QTY: 2
Now the trans mount is bolted on to the trans. Now we'll see about setting that bad boy on the trans cross member.
