| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Hello All, Can anyone tell me what size bolt w/tread the mounting bolts are for the T5?
Bread | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Use your original bolts,the threads are in the bellhousing not the t-5.You will have to drill out the t-5 mounting holes(4) to 1/2".
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Bowtietim, My apologies, I wasn't very clear on what I was asking. I am asking for the bolts that bolt up to the crossmember mounting pad. I do have the everything you mention completed. clutch housing to trans Bread | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If your talking about the transmission mount bolts(2)I know the head is 15mm.I'm not sure of the thread size.
| | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Bowtietim, Thanks for the help.
The third time to the Auto Zone did the trick. Dorman 980-530
M10-1.50 x 30mm HEX FLANGED CAP SCREWS QTY: 2
Now the trans mount is bolted on to the trans. Now we'll see about setting that bad boy on the trans cross member.
