8 members (55shaker, RoadsScholar, warlock, 5 Window 9434, Otto Skorzeny, k2handyman, 6inarow, 1 invisible),
85
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90539 10/31/2002 4:24 AM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | My '54 3100 has a aftermarket wiper assy. that was in the truck when I got it. The only thing is that's as far as they got. The wires are just hanging under the dash. Does anyone here know where I can get a wiring diagram for one of these? I haven't needed them for the last 8 months, but winters comin'. :confused:
Whoever owned her before must have been a contractor, no offence to anyone. Most of the wiring was done with those twist nuts they use in a house. I'm redoing her a little at a time.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
#90540 10/31/2002 2:03 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wingnut,
A 1954 accessory installation manual would have instructions for the Chevy 2-speed electric wiper mechanism (that should also work for an aftermarket wiper mechanism). Check the vendor links. A 1954 wiring diagram (booklet) is also available from most vendors.
There are a few places where you can connect a hot lead - at the ignition switch or at the rear of the light switch are two options. Run a hot lead to the wiper's on/off/control switch. A lead should go from the control switch to the wiper. The switch is grounded when attached to the cab. How many leads on your wiper? I do not remember how many leads are on the original accessory wiper (I will check tonight).
I trust others will will correct me and/or add suggestions. Also, I do not know about the need for an in-line fuse.
Tim | | |
#90541 10/31/2002 4:28 PM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | When I got the truck it all ready had the aftermarket unit in it, so I don't know how many wires it had.
