1 members (Gdads51),
124
Mod | | | Forums66 Topics128,204 Posts1,057,312 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | So, as some of you might have seen, my water pump pulley parted company with its self. Apparently it was an aftermarket pulley, and the machined hub was furnace brazed.
At any rate, I'm wondering if any of the BC bolters has a spare 216 pump pulley they'd be willing to part with, otherwise, I need to order a new short shaft water pump from one of the USA vendors.
This is a new pump on my 235, and I'd like to not have to buy another pump, as I'm hoping to replace this engine with a mighty 216 in the spring. I'd rather spend the $150 on bearings, but I need to stay on the road as I use my panel truck for work. I've put over 10,000 miles on it in the last year.
The cheap part of me wants to just JB weld the hub I've got back together, but having the fan go through the radiator sounds like it would cost more than a new pump! I've also considered brazing it back together too. But again, that's probably not as good as just replacing the pulley with a good GM one!
Thanks.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mr. Lang, I probably have one, can you send me the width of groove and diameter measurements, and I'll check. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Okay Bobb, I'll measure it up in the morning. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Okay, the specs of the pulley/fan hub are as follows: (this should be a stock GM 216 part)
3/8" Groove for belt
Outside diameter 4 5/16"
and a 5/8" shaft.
And thanks for taking the time to check for me Bobb!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | | | |
