8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | Does anyone have information or experience in converting a stovebolt body to a s-10 frame?If you do I would appreciate some input on what to do.Thanks for your time. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Its been done many times. If you do a search you will find many posts about it. | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Agree with don stocker. What year stovebolt we talking about? 55 1st searies and earlier is a bit differant set up as compaired to 55 2nd series and newer. I am assisting a buddy with a 59 to S-10 set up. Most of the modification was to the box bottom, and adapting the original radiator support to the front of the S- 10 frame. However, depending on the "look", "stance", "motor n trans combo" etc., modifications will differ from one project to another! A tape measure will become your BEST FRIEND!!!!! | | | | | Joined: Sep 2012 Posts: 6 New Guy | | New Guy Joined: Sep 2012 Posts: 6 | You may want to look at ad-engineering.com. Kits are available and 2 or 3 tape measures,levels,clamps,etc. etc. are in order... | | | | | Joined: Oct 2012 Posts: 27 New Guy | | New Guy Joined: Oct 2012 Posts: 27 | If you go on killbillet form to there's a lot of guys doing them on there to | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | go to www.e-zchassisswaps.com .....they have the complete kits for what you want to do
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | why would anyone want to do that, they look and ride great on a stock frame Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | Different strokes for different folks! Depends on what they want out of a project. Also I've had several 1/2 tons that amazingly the body held up better than the frame. shoddy repairs, cracks and rust out. S10 frames are plentiful. Although I keep a couple extra frames around for purist. MONGO | | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | Thank you for your responce.I am looking to convert my 52 chevy truck to an s-10frame.I was told that a long bed reg. cab s-10 is the best with the least amount of modifications. | | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | | | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | Thanks.I got that website from a person posting an s-10 ad. | | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | | | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | Thanks for your responce.I am still thinking of using my original frame.I was told I could take like four leafs from ea. spring and get a lower stance and a better ride,plus better handling.Do you know something about this? | | | | | Joined: Apr 2012 Posts: 21 New Guy | | New Guy Joined: Apr 2012 Posts: 21 | Thanks for the responce.I will check out your website. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i took 4 leafs from the bottom of my springs and put them on top of my springs,it lowered my rear 2 inches (see pic) I cut the 4 leafs 3in. on each side of the center bolt to make them 6in total to make a homemade lowering kit and still use the same center bolt [IMG] http://i629.photobucket.com/albums/uu14/kurtdh519/022.jpg[/IMG]
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | One of the fellows on this site - BC52 - has a '52 with a Nova front clip and bagged rear. His truck sits nice and low. May want to contact him for details. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That's another option, but clips aren't for the faint of heart. I say this as I've seen way too many poorly done clips by guys that were way over their head. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | You may want to look at ad-engineering.com. Kits are available and 2 or 3 tape measures,levels,clamps,etc. etc. are in order... i purchased one of these kits and then decided to go another direction, it can be had pretty cheap if interested. | | |
