4 members (rfs56trk, Hotrod Lincoln, dgrinnan, Otto Skorzeny), 108 guests, and 2 robots.
Topics128,164
Posts1,056,968
Members48,458
Whats the best way to lower 12 volts to 6 for the gauges? I've seen some devices that aren't meant for gauges, only larger amp items like blower motors. The ones I've seen for gauges are just a resistor... Is there anything better out there?
I need it for 2 gauges...gas/temp.
'53 Chevy truck 1/2 ton
The Moderator (Fifthave) of this forum has something that can do exactly what you need..............
I'm sure he will be along here shortly.
That or someone with a better memory than mine.................
It's not a hokey-pokey thing either, it's a tried and true unit.............
It's on the tip of my tongue; I just can't remember!! :mad: :mad:
Fifthave can be found at:
Fifth Avenue Antique Auto Parts 415 Court Street Clay Center Kansas 67432
*** GMC ***
Resistors are fine. I would just make sure
you got a good quality one. I plan to use them
on my build and I like the look of the ones I
got from Jim Carters. The gas unit is a #EL311
and the others are #EL135.
Don't resistors get hot?
Yes, they do. I used one on the '51 GMC I had for the fuel gauge. I used an aftermarket Stuart-Warner mechanical temp. gauge. Picked up the resistor from The Filling Station. It worked and had good directions for installing.........but it did get hot while operating.
The device I was trying to remember..........
The Runtz!! Ask Fithave about it.........email or PM him........there were threads about it in the past; but it was quite a while ago and probably not in the archives here.
I believe it will operate both of your gauges.
*** GMC ***
kevmor99,
Search in this forum for "Runtz", There is a lot of information to be found.
Here is one thread: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=000663#000000
There was a very good article by Randy Rundle on this topic in the January 2004 issue of "Auto Restorer" magazine.
Tim
I've had a runtz controlling my gas gauge for almost 2 years without any problems. Just make sure you have good grounding.
Craig
