12 members (Gdads51, greenie-reddy, Simso, Joe H, 1955 1 Series, Southerntruck, Gib70, 3B, Peggy M, Oswald, Jon G, 1 invisible),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | or is it better suited for the mercruiser boat engine? Or are they the exact same? If it has hardened seats installed it'll be a pretty good deal because I can save 40-50 bucks shipping and pick it up locally. Thanks! http://cgi.ebay.com/ebaymotors/ws/e...9&category=50442&sspagename=WDVW | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Not 100% sure it will fit , but it might, maybe E-mail them and ask them. Looks like it has holes in the exhaust ports for emissions. If you don't have that, you will have to get plugs to block them off | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Originally posted by Big T: Not 100% sure it will fit , but it might, maybe E-mail them and ask them. Looks like it has holes in the exhaust ports for emissions. If you don't have that, you will have to get plugs to block them off Oh. I see what you mean. Won't work for my app. Good catch! Thanks! -ftyler | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Emissions air tubes on a boat engine? Boat engines have no emission controls.That means the head casting must be the as truck/car versions, ya think?.6 pipe plugs cost 4 bucks  | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Those exhaust port holes are no problem at all. Just screw in some 1/4" pipe plugs with a little LocTite, and press on! They're for air pump equipped, emission-controlled engines, but there's virtually no difference from the earlier head, IMHO. Jerry
| | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Outta work--if you can get it for $110--there appears to be no reserve at that price--heck of a deal.
Gotta say--when I see those head bolt bosses stickin out of those intake ports--really pretty shocking even compared to a 235/261 head. Really outta be some kinda penalty for poor enginneerin like that--really disgustin. :mad: No wonder those inliner guys are cuttin out those bosses and puttin in lump ports.
Buzz'n Half Dozen
| | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | it will work on a 250 motor | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I wonder if, because this is a later 6 head (certainly from a 70s 250 or 70s/80s 292), then it has the hardened exhaust seats installed. I guess I could ask the rebuilder to see what they say.
What do you guys think? | | |
#9052 10/10/2004 11:26 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 292s were tough stuff. They had hardend seats & valve rotators on the exhaust valves. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | I ran a head just like that one. Mine made a whistling noise from the exhaust ports due to the smog tube holes. I had standard brass plugs in them. One of the racing manuals said to install long brass plugs and cut the extra off in the port so you fill as much of the hole as you can. I just changed heads and the noise went away. Joe | | | | | Joined: Sep 2004 Posts: 16 Junior Member | | Junior Member Joined: Sep 2004 Posts: 16 | Looks the same as my '84 292 head. I think GM calls 'em "Heavy Duty Emission Control" heads.I also just used iron pipe plugs to close the A.I.R. ports off. This will certainly have unleaded seats. Jim.
Stranded in time. Surrounded by evil. Low on gas...
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Will the smog holes need to be tapped or are they pre-threaded?
-ftyler | | | | | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | They are pre-threaded. I put in some plugs on my (250) head and it works great, no leaks. Dan
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
