Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible), 126 guests, and 3 robots.
Topics128,283
Posts1,058,513
Members48,490
#904879 12/19/2012 11:37 PM
I
I Offline
Anyone know of a source for 292 motor mounts?
Langdon doesn't carry them and I haven't been able to locate another vendor.
The 292 is going into a 40 1/2ton.
InMy40s #904928 12/20/2012 7:53 AM
I think Classic Performance Parts carry an adaptable set.You weld brackets to your frame and use the supplied metal and rubber donut mounts.
Drew
DrewP #905010 12/20/2012 12:53 PM
You'll either have to buy or make an adapter plate with that because the motor mounts are offset on a 292
InMy40s #905160 12/21/2012 3:08 AM
I investigated this a little when I knew I'd be replacing the 270 in my '57 GMC 2 ton,but ended up going a different route.
I think a V-8 side-mount conversion "tube" type crossmember might work with a little modifying. Near as I can recall,the stagger from one side to the other on a 292 is about the width of a V-8 motor mount,so if you make a couple of plates to weld on and offset one about half a motor mount width forward of center on the left and offset the other one the same amount to the rear on the right side,and drill the motor mount holes to match the new "stagger",it should be a relatively close match. This is just my opinion,above all else,measure everything,re-measure,double check and measure it again,and keep checking your measurements. It's a lot easier to fix a mistake when it's still just one than it is to have to fix a bunch of mistakes that were all based on a mistake made early on. There's probably quite a difference in frame width from your '40 to my '57,but I'm sure someone can fill you in on that.
When I put the 292 in my '57 GMC dump truck we made a saddle mount that bolts to the front facing of the engine. That enabled me to use all the stock '57 mount cushions,etc. ,it left clearance for the exhaust and other stuff that was otherwise in the way and all the clutch linkage lined up like original. The mount turned out pretty homely,but works great.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
