0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#90498 07/27/2003 9:03 PM
Lew
Offline
I have a 51 3604 with a 235 and six volt system. It starts great when cold, but when it is warm and I shut it off it will barely turn over when I go to restart it. It seems to me that the battery is good as it starts the first time. Do I have a bad starter, or are there other things I need to look at?
Thanks for the help!
Better to be lucky than good.
#90499 07/27/2003 9:30 PM
Lew, You need larger battery cables. Check out this thread..
The subject is about 12 volt conversion, but the info applies to checking out your 6 volt system.
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#90500 07/29/2003 5:09 AM
Lew
Offline
53 4 me
You da man! Funny, electricity. It turns over like a striped ape now, thanks!
#90501 08/18/2003 7:14 PM
I had the same problem and replaced the cables with 2/0 welding cable and it fixed my problem too...! I agree, you da man "53 4 me"...! Thanks for the help...!
