10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
94
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Possible. Can you get the block casting number?
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No, that "plumbing" does not look "correct", or at least it does not look "normal". Here are locations of casting codes and engine ID. Post the codes here and people will be able to tell you what type of filter is appropriate. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | No on the oil lines & flter and don't think it a 261. Casting #? captians bars above starter?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 |
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That looks like a 1960-62 engine. I would say it is a 235.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I was thinking if it was a 261,there will be captain bars above the con#. The casting number looks like 3769716 to me.If it is it is a 58-62 235 engine.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | Picture is not crystal clear but the rearmost gaggle of fittings/lines appears to be where one of the full flow oil 261 fittings would be, (never seen one plumbed that way)and lower on the block just behind the side motor mount triangle of holes appears to have some sort of fittings(?) that are not connected to anything--that is where the other full pressure 261 fitting would be. Maybe it is a 261. I would also look just above the starter area and on the same side of the block behind the manifolds (just below the deck surface-and mid block) for "captain's bars (manifolds are blocking this area from view). to help seal the deal. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wouldn't the rearward oil line port on a 235 and 261 be in generally the same location?
The only certain way to tell what you have is to post the block casting code and the block casting date.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All 235's have 1/8" pipe fitting connections on the block. 1954-57 261 also have 1/8" fittings, but in 1958 when the full flow filter was added the fitting size increased to 1/2", There should also be a pin ahead of the supply port which was to control the oil flow depending on whether a filter was used or not. His engine pic does not have the control pin.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | just trying to compare his picture to the inliners "forgotten 261" pictures... has anyone been sucessful in pulling the pushed in plug back out so you would'nt have to use the filter or a big clumsy bypass loop?
Surely someone ought to be able to drill them out like a broken stud and then tap it for a pipe plug | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have tried but it is not possible without drilling and threading the pin for a puller bolt. There is no access from the inside either.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | I have in the past, had a '59 and a '62 261, and both had the plug pushed in, forcing the use of a filter or a big hunk of expensive brass that just dont work neatly. On the second one, I used something similar to a power steering hose setup, it too worked, but it was very bulky and really a pain to snake the exhaust past all the oil plumbing. On the first 261 (this was in 1962) I used a brand new genuine full flow chevy filter and hoses. but when the next 261 came around ('bout 1974), these filter assemblies were not so easy to find, so I used a bypass and no filter. I had a '54 vette intake and exhaust so the filter housing would not attach well to the more square vette intake manifold (besides it would ruin the looks of the three carb setup). With the huge diameter hose the motor would not pressure up immediately, sometimes taking 10-20 seconds to get oil pressure while the hose would "fill up", some times you could hear (or imagine to hear) a main rumbling. scary--this is why I wished you could pull out that pressed in gallery plug. Folks told me it was impossible to pull it back out. (for sure once the motor was in the car) | | |
