7 members (Jims46, Otto Skorzeny, dt235sd, 2-Ton, tclederman, Bill Hanlon, Millenimech),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 24 New Guy | | New Guy Joined: Dec 2012 Posts: 24 | I got a 51 GMC 450 with the 270 I6. Whats the top speed of these trucks? Don't plan on cruising down the I-10 at 75, but I am curious. | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | It depends on how much noise you can put up with. We used to run them 60 all day long and 70 down hill. You aren't going to hurt the engine at high rpm, but they get noisy and lots of wind noise. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | brakes first!!! that whats more importaint, is can you stop? | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | ken is right with the tolerance of sound. at one time i was wondering the same thing just like you. after i got my trucks to stop and steer i took them out. my sound tolerance in my 40 is less than the other two but thats due to some improvements from 40 to 51. i run mine from 0 to 52.5 mph. depending on the condition of the engine you might tolerate the noise but the motor wont tolerate the speed  guess how i know this  there is a sweet spot that the truck likes the best. find it and drive it at that speed. | | | | | Joined: Dec 2012 Posts: 24 New Guy | | New Guy Joined: Dec 2012 Posts: 24 | Thanks for the info,deffinately will do brakes before I get it out on the road. I really like your dumper, 51ashton. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | so does that guy that goes by the name of tclederman, after he drove it  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, your dump truck drives nicely with the rebuilt engine. But, I still do not think I was driving it, Mike. I was a monkey that was simply following the instructions of my excellent trainer. Double de-clutching and two-speed switching - sheesh? Too complex for this simple mind. However, I'll eventually learn, hopefully before I wear down gear teeth. Maybe next summer; maybe summer 2014? Slow but almost steady with the restoration of my COE. Merry Christmas | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I drive my '53 6400 Firetruck 45-50 if I'm on the highway. I have run it 60 but its not real happy doing it. If you look back at the roads these trucks operated when they were new you would find that 45 was the speed limit for trucks. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I drive my 52'GMC 454-30 at 55 MPH. that is the fastest it will go.
It has a governor under the 2 barrel carb and a raised metal stop plate under the throttle pedal.
It purrrrrrs at 55 and gets good gas mileage at that speed.
Also another thing some people forget is not only the brakes but the front axle wheel bearings are not designed for modern highway speeds. It is a good idea to upgrade wheel bearings to a higher grade bearing. They cost more, but are worth it if you plan on spending much time on the freeways and turnpikes.
And good tires as well
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Dec 2012 Posts: 24 New Guy | | New Guy Joined: Dec 2012 Posts: 24 | 55 sounds good, no reason to go faster. Thanks guys
