9 members (Gdads51, jmoore, Danielbolt, JW51, Rusted Nut, 2-Ton, GA Boy, cmayna, 1 invisible), 64 guests, and 2 robots.
Topics128,169
Posts1,057,041
Members48,458
#904753 12/19/2012 3:53 PM
Im swapin the third member from a 56 into my 53. the pinion needs a new seal, the local rear end guy said he wouldent want to change it because the pinions wear down and replacements arent avail. any thoughs?
Riding in the Passing Lane
Replaceing that seal should be no problem. If the flange is scored where the seal rides there is a sleeve available to cover it. Any parts store should be able to supply them. Mark the position of the nut to the shaft before you remove uit & put some locktight on it when you go back.
1972 Chevy c10 Cheyenne Super
