4 members (5 Window 9434, ronsway, NJC, dt235sd), 152 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
or is it better suited for the mercruiser boat engine? Or are they the exact same? If it has hardened seats installed it'll be a pretty good deal because I can save 40-50 bucks shipping and pick it up locally. Thanks!
http://cgi.ebay.com/ebaymotors/ws/e...9&category=50442&sspagename=WDVW
Not 100% sure it will fit , but it might, maybe E-mail them and ask them. Looks like it has holes in the exhaust ports for emissions. If you don't have that, you will have to get plugs to block them off
Quote
Oh. I see what you mean. Won't work for my app. Good catch! Thanks!
-ftyler
Emissions air tubes on a boat engine? Boat engines have no emission controls.That means the head casting must be the as truck/car versions, ya think?.6 pipe plugs cost 4 bucks grin
Those exhaust port holes are no problem at all. Just screw in some 1/4" pipe plugs with a little LocTite, and press on! They're for air pump equipped, emission-controlled engines, but there's virtually no difference from the earlier head, IMHO.
Outta work--if you can get it for $110--there appears to be no reserve at that price--heck of a deal.
Gotta say--when I see those head bolt bosses stickin out of those intake ports--really pretty shocking even compared to a 235/261 head. Really outta be some kinda penalty for poor enginneerin like that--really disgustin. :mad: No wonder those inliner guys are cuttin out those bosses and puttin in lump ports.
Buzz'n Half Dozen
it will work on a 250 motor
I wonder if, because this is a later 6 head (certainly from a 70s 250 or 70s/80s 292), then it has the hardened exhaust seats installed. I guess I could ask the rebuilder to see what they say.
What do you guys think?
Riding in the Passing Lane
The 292s were tough stuff. They had hardend
seats & valve rotators on the exhaust valves.
1972 Chevy c10 Cheyenne Super
I ran a head just like that one. Mine made a whistling noise from the exhaust ports due to the smog tube holes. I had standard brass plugs in them. One of the racing manuals said to install long brass plugs and cut the extra off in the port so you fill as much of the hole as you can. I just changed heads and the noise went away. Joe
Junior Member
Junior Member
Looks the same as my '84 292 head. I think GM calls 'em "Heavy Duty Emission Control" heads.I also just used iron pipe plugs to close the A.I.R. ports off. This will certainly have unleaded seats.
Jim.
Stranded in time. Surrounded by evil. Low on gas...
Will the smog holes need to be tapped or are they pre-threaded?
-ftyler
They are pre-threaded. I put in some plugs on my (250) head and it works great, no leaks.
Dan
69 C10 LWB 250 L-6/3spd
79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
