1 members (Erniegp),
47
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | How can I tell if a generator is 12 or 6 volt?
What happens if I run a 6 volt on a 12 volt system? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | black tag = 6V, red tag = 12V
if you've got a 12V battery it won't get charged
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If the tags are missing examine the generator body if it has been rebuilt shops often stamp the voltage on. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | No tags, no stamp.
I'll just leave it on the engine when I do the swap. Then put a meter on it and see what happens. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There should be a number stamped into the body. Somewhere I have a Delco document that lists the numbers. I used it to identify a 12 volt that I bought. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Numbers stamped onto the case may not provide the definitive answer. ClassicGenerator recently built a generator for my '54 using a correct 6v case with 12v guts inside.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
