1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90400 05/03/2004 6:02 PM | Joined: Nov 2002 Posts: 9 Member | | Member Joined: Nov 2002 Posts: 9 | I have installed Chevy Duty's wiring harness and turnsignal switch, in my 51 GMC 1/2 ton.
The front turnsignals work fine (but) I can either have turnsignals or brakelights on the rear, not both. I choose brakelights.
Has anyone else run into this problem?
#90401 05/03/2004 7:06 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Is the wire from the brake switch going into your signal unit?
Joe
#90402 05/04/2004 5:11 PM | Joined: Nov 2002 Posts: 9 Member | | Member Joined: Nov 2002 Posts: 9 | Sorry I didn't get back earlier, my computer at home got the new sasser virus. I beleive I connected it at one time. But now I just have the brake lights connected to the brakelight switch.
#90403 05/04/2004 5:47 PM | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | I installed what is probably the same signal switch last year. It took a little fooling around, but in the end I just followed the wiring diagram included with the switch and everything works perfect.
I do know that the signal light switch gets wired into the brake light switch.
I hope this helps
Rob | | |
#90404 05/04/2004 6:43 PM | Joined: Nov 2002 Posts: 9 Member | | Member Joined: Nov 2002 Posts: 9 | I just printed the wiring diagram from "headlight wire colors" on this forum. That is so clear that even I can follow it and it is in color too.
The wiring diagram that came with the turnsignal switch was not clear to me. It said things like (cut & tape brown wire' etc.) cut & tape it to what? Any way we'll see how the color wiring diagram works out.
#90405 05/05/2004 1:43 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Jerry - "cut and tape" means to cut the end off the wire and put a piece of tape over that end to prevent it from shorting out to anything and keep it outta the way cuz it ain't needed - some harnesses will have extra wires for other applications
Bill | | |
