Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible), 126 guests, and 3 robots.
Topics128,283
Posts1,058,513
Members48,490
#903881 12/15/2012 9:30 PM
I
I Offline
How can I tell if a generator is 12 or 6 volt?
What happens if I run a 6 volt on a 12 volt system?
black tag = 6V, red tag = 12V
if you've got a 12V battery it won't get charged
If the tags are missing examine the generator body if it has been rebuilt shops often stamp the voltage on.
I
I Offline
No tags, no stamp.
I'll just leave it on the engine when I do the swap. Then put a meter on it and see what happens.
There should be a number stamped into the body. Somewhere I have a Delco document that lists the numbers. I used it to identify a 12 volt that I bought.
1951 1 Ton Completed
Numbers stamped onto the case may not provide the definitive answer. ClassicGenerator recently built a generator for my '54 using a correct 6v case with 12v guts inside.
- Lonnie
My '54 3104
