3 members (papas52, Jeff Ogden, Otto Skorzeny), 141 guests, and 0 robots.
Topics128,163
Posts1,056,921
Members48,458
I replaced my old 235 with a new to me 235. I have compression, weak spark and gas through the carberator. I made sure I was top dead center and took the ignition wire and unhooked it from the resister and bolted it to the positive side of the coil. any help would be appreciated.
Bert
3B Offline
Hy berts53, verify your timing one more time by removing number one spark plug, and feeling for compression coming out of the hole as you "crank" the engine over. If your vehicle has a resistor then it should also have a resistor bypass circuit to provide twelve volts to the coil while cranking the engine to start, does it have that circuit? Cranking is what is done to the engine with a hand crank or starter motor, running is what the engine does once the engine is started by the cranking. Are you saying that that the starter cannot "crank" the engine over so it can start if the conditions are correct for it to do so?
You might want to check your ground connection. Also check the condition of your battery and make sure it has a full charge in it. I would caution against using jumper wires and keep things the way they are supposed to be, just make sure everything is the way its supposed to be.
Found the problem. The hose coming off the air intake to the windshield wiper was leaking. I plugged the hose up and it fired right up. Thanks, Bert
