7 members (baldeagle, Hotrod Lincoln, Bill Hanlon, fonz8261, greenie-reddy, 2 invisible), 367 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
1 Offline
The fit is sloppy and I don't know why kind of sealer to use. I certainly don't want something dripping into the crankcase that could do harm. What do I use to insure a good, tight, long term seal? thanx
http://s1233.photobucket.com/albums/ff393/fletch41/
1941 Chevy 1.5 Ton, (soon to be flatbed), dubbed the "USS Coral Sea" which I served on while in the military. wink ~m
wink
~fletch
try to spread the end slightly first, it was originally a press fit and likely got scrunched a bit by removal
As Bill stated you could expand it slightly.
Blue (med stregnth) locktite or locktite pipe sealant w/ teflon (like the tape only liquid in a tube) will give an tight seal to the block.
BC
1960 C60 pasture art
1 Offline
Thanx Bill, I'll give that a shot. Now, what kind of sealer do I use?
wink
~fletch
1 Offline
Thanx BC, I'll run over to napa and see what they have.
wink
~fletch
