| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I recently, just Wednesday, installed a Saginaw '69 3sp+od. I have had the incredible Muncie 3sp+od these last ten years but it was a change for the better. In it's Muncie form I did not use the governor. I used a simple on/off switch powered by the key on/off to the solenoid.
In the Saginaw I would like to use the governor w/o a kickdown either on the carb or under the accelerator. In short, I would like to use the governor to switch on the solenoid via a relay; I would also like to be able to operate an on/off switch to enable the transmission when in overdrive to downshift into 3rd regular.
30- swiched power
85- ?
86- ?
87- ?
Please don't include any Chevy or Ford or any other manufacturer diagrams as they don't use a modern Bosch relay and they use a kick-down which I desire not to use.
Thanks for all help and experiences.
Regards,
Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used a DPDT switch in lieu of the kickdown switch. I wired it like this. | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 |
