6 members (Paul_WNC, Gdads51, Shardean, Greg_H, NorCal52Suburban, Waveski), 60 guests, and 6 robots.
Topics128,021
Posts1,055,357
Members48,420
#9031 10/25/2002 8:09 PM
Hey all, on my 52 AD the pedal that I push to start my truck does not engage when I press down on it. I always have do raise the pedal in various positions in order to get it to start. is there an adjustment to where I can fix this .I see a u shaped clip on the rod that engages the starter is that by chance the adjustment?or is there someplace else that I'm not seeing here. one day when the rich uncle decides to leave me all that money I can afford a manual. thanks for reding to all who does
#9032 10/25/2002 8:54 PM
I think you probably need a new switch. Does it spin and make noise when you are moving it around, or only when you get it to the right spot? The linkage consists of two parts, the part that slides the gear on the starter in and out and the switch that contacts the lever to spin the starter.
Paint & Body Shop moderator
#9033 10/25/2002 10:00 PM
4onthefloor starts good when you hit the right spot I really dont think it's the starter it's self but I've been wrong b4 I'll get someone to try and start it while I have a look see thanks
#9034 10/25/2002 11:16 PM
Im geussing josiah is corect.To test his theory simply remove the switch on top of the starter and turn the contact around and replace it.If that works your good to go untill that side wears down and then it will need to be replaced.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#9035 10/26/2002 2:41 AM
Another way to check is to use a prybar to move the lever on top of the starter and see if that works. If it does, you have linkage problems.
Fred
52 3600
69 C-10
#9036 10/26/2002 1:40 PM
Thanks FredT will try what you suggested today wheather getting a little cool here need to adjust,repair whatever is gonna be done b4 too much longer or I'll be laying in snow or waiting till spring.
#9037 10/26/2002 1:45 PM
A sagging or rusted cab can change position , and not allow the pedal to fully engage.I had that problem with a 49 GMC.Or it may be what the guys above suggest.
#9038 10/29/2002 12:14 AM
V
V Offline
Is the return spring still on the linkage ? I see where you said " have to lift up on it " there should be a fairly robust spring to return the pedal when released , it's a coil typ retraction spring .
When you remove the starter switch to rotate the contact , also be sure to polish both contacts untill shiny .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#9039 10/29/2002 2:28 PM
Tony is dead on from my experience. Cab mounts are probably shot and have misaligned the starter rod. Any problems with brake and clutch pedals binding on the shafts?
