| | | Forums66 Topics128,042 Posts1,055,602 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I just replaced my 235 with a 250 in my '59 Apache. It is leaking coolant at the front of the engine somewhere. I can't find the source because it don't do it constantly. It seems to do it before the engine has warmed up. I am thinking it might be the water pump gasket when the thermostat is closed but am worried that it might be the head gasket. The oil and water are not mixing or anything like that. Coolant is just coming out somewhere. Any advise would be appreciated. Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Take an inspection mirror & look under the water pump in back of the pulley. There is a vent hole in the pump. If there is coolant around there then the pump is leaking. I doute it is a head gasket. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | I think if it was a head gasket you'd know by now haha, I'd take off the water pump and replace the gasket, use plenty of silicon on this one. replace the gasket on the thermostat housing too. It could even be your hose isn't clamped down tight enough. | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | Thanks for the replies. I went out this morning while it was still cold and stated it up and watched it til it started leaking. It was coming from the upper heater hose where it goes into the bottom of the thermostat housing. I am pretty sure that I fixed the problem. Thanks again, Gene
Gene 1959 Apache
