8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible), 74 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#903366 12/13/2012 4:57 PM
Is draining the bad gas out of the tank of a long-sitting truck good enough ? Probably not smile .... I will probably go ahead and pull it... Do I just loosen the band screws and try and negotiate/pull the neck thru the rubber gasket ? Do I need to try and save the gasket ?
Troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
I disconnected the straps completely.It's easier with the gasket out. I was able to save mine on the '42. Just push from the inside and pull with you other hand. Should be the same for your '51.
Thanks Alltruck, I appreciate the advice... Sounds like a good plan.
Troy
Troy
1963 Chevy C60
Big Red Chevy
