8 members (walter74, mvigo, Forty9, Shaffer's1950, Rusted Nut, mick53, Wally / Montana, klhansen),
114
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | i wanna put a 3 speed coulmn shift I got in my 53 burb. my steering column dosent appear to have holes to mount the bracket, just under the steeing wheel. Am i missing somethin or do i need a column [censored] column? can i just drill into my column> | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The trucks that came from the factory with 3-speed transmissions had the holes for the shifter "collar". The trucks that came from the factory with a 4-speed transmission did not have the holes for a 3-speed shifter "collar".
You could drill and tap holes in the column for the collar, but I guess that you would have to be careful about metal filings getting into the steering column?
Maybe someone who has done this will post a technique and/or precautions.
| | | | | Joined: Jun 2008 Posts: 19 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 19 | It is theoretically possible to drill holes, but you will be tapping holes in 16 or 18 gauge metal and will not have much thread area (less than one turn) You could drill the holes oversize and put nuts on the inside. In order to do this, you would need to remove the horn contact ring fron the end of the column tube, and use a long 7/16 open end wrench with a little piece of masking tape to hold the nut while you start the bolt. Unfortunately, if you were to ever have to remove the shifter would lose the nuts, unless you repeated the process with a telescoping magnet. Let me know what you decide. PM or email [email protected]When the columns were originally made, these holes were punched, which left about a 1/8 to 3/16 sleeve to tap threads into. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | It is possible to just replace the upper tube also. You will break the gasket at the top of the steering gear when you un-bolt the 4 bolts and than swap the tube. Granted, I think the steering column will need to be out of the truck too when you do this. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I would bet (and not lose the bet) that the thickness of the metal in the steering column is greater than 16-18 gauge. Nonetheless, whatever the thickness is, it must be thick enough for the bolts/screws for the standard 3-speed shifter collar.
If I had to drill holes in the column, I'd probably replace the column with a 3-speed column, as Greg suggests.
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You could also use epoxy and forget about drilling the holes. Or you could make a split bracket that goes around the column and fasten the shifter to it.
Kurt | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Why not try to find a 3speed column? If I were closer to Colorado, I'd trade you one. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | so.. I noticed the column in my truck has a oval shaped cut out that the shifter box mounts to. but when I looked at my buddy dicksons 51 gmc, his column didnt. is it possible my column has the holes but its just coved by paint/the blinker. why would It be cut out down there if its not a 3 speed column?? ?
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | hahahah!!!! i SANDED THE COLUMN AND FOND THE HOLES FILLED WITH J.B! WELD! | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | So it started "life" as a 3-speed truck...
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sounds like it went though a cosmetic shift-change operation? Good thing it is a reversible procedure.
