9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
#902807 12/11/2012 12:16 PM
Hope the experts can help...
I have seen 2 different type fans on 54 chevy truck 235's... both are 18in diameter w/4 staggered blades , but the blade widths differ. Is one for passenger car and the other is truck. or is it thiftamaster vs loadmaster vs jobmaster?
Cannot find anything in the old literature and was curious why the difference?
-Paul
There were two 1954 fan blades, with 4 blades or 6 blades.
You'll see at the link above that there was an earlier, different, 4-blade fan.
It is highly likely that the different 4 blade fans you have seen were from different years, pre-54/55, 54/55, and post 54/55 (however, later 4-blade fans had a larger diameter).
Tim,
Thank you, this was a huge help. smile Once I had a part number to reference it was easier to determine which fan was which. Much appreciated...
Thanks again,
-Paul
