0 members (), 109 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#788630 10/13/2011 10:57 PM
I have a 1963 c30 flatbed dully that i am starting to restore. I want to up date my rear end so i can drive on the highway with today's tires at today's speed.Is there a later model rear end that i can install in my truck.
bill 63 #789541 10/17/2011 4:02 PM
is your rear axle a Eaton or Dana , i found myself forsale a 1967 c30 the rear axle most likey 514 so im going to put in 457 or 411 when i get the truck , if you have Eaton 457 or 411 if you have a Dana 456 or 410 , im not sure about 373 , no one wants 617 538 514 of Eaton 513 of Dana , in the mid late 70s when they came out with the 14 bolt rear axle and still made the Dana but stop making the Eaton , i am Allen im in FL for now
chevy67292c30 #794218 11/01/2011 2:37 PM
Heavychevy.com has a 3.90 and 4.10 gears for 62-72 trucks, try giving them a call.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #884818 09/26/2012 7:01 AM
It's a eaton! Didn't know if it would be cheaper to Chang out the gears or swap the rear end.
bill 63 #884915 09/26/2012 2:18 PM
Crusing in the Passing Lane
GM 14 bolt FF axles are usually $150. or so around here, good ratios.
EdPruss #885011 09/26/2012 9:19 PM
Since I posted last, I have purchased a full floating 14 bolt rearend. They have more gearing options and parts are readily available.
"The Fake Truck"
bill 63 #885426 09/28/2012 8:42 PM
Thanks guys i appreciate the help!I do have a couple of u-pull it's near me, what vehicles did those gm full floating axle's come in and do i need pacific year thanks.
bill 63 #885695 09/30/2012 12:50 AM
Bill- Try finding one from a dually truck. Most of them are 63" WMS-WMS (Wheel mounting surface-Wheel mounting surface). Your Eaton axle under your truck now is 62.5 WMS. As far as years, anything from 72 to present should work.
"The Fake Truck"
bill 63 #886062 10/01/2012 9:15 AM
Thanks! will go this weekend and see what i can find.
bill 63 #887961 10/08/2012 7:13 PM
See note
Last edited by Grigg; 10/08/2012 7:42 PM. Reason: please use swap meet or PM to buy/sell items on this forum.
Currently cruising
in the
Passing Lane
bill 63 #902954 12/11/2012 10:17 PM
I found a 87 Chevy 1 ton with a full floating 14 bolt rear end,and the price was great to! free
Moderated by  Dusty53
