1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Im trying to have put in a rear license plate light on my 1964 k10t. I replaced my rear electrical harness with a new one. It has an extra "connection" running along the harness in light green wire. Is this wiring for the license plate?
There is also a wire coming out of a cluster of others near the starter under the hood with a connection that would fit to the connection on the rear wiring harness.
If in fact this extra wire on the rear harness is for the the license plate light should I plug it into the wiring/connection I mention above? Thanks John
1964 K10 Fleetside Pickup Truck | | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | John shoot me an email with a couple of photos of the wiring and I will see but It sounds like back up light wiring if it is light green. I will check my wiring diagrams to be sure.
65 K10 Longbox Fleetside Big Back Window Custom Cab 65 K10 Flatbed Old School Parts 60-66 (208)946-6173 [email protected]
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I believe the brown wire that is common to both the left and right side tail lights is the wire that is used to power the license plate light. This wiring diagram confirms the brown wire: http://67-72chevytrucks.com/vboard/showthread.php?p=2955936Dark green would be for the right side turn signal indicator. Hope this helps :-) | | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | This is helpful. In the last diagram with the detail of the taillight....there is a symbol on the brown wire leading to the license plate light. Is that a fuse?
1964 K10 Fleetside Pickup Truck | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I think that symbol is for a plug to power the circuit. That way a stepside, vs. a fleetside, vs. a chassis cab could have a separate length license plate wire for whichever application is needed. | | |
