2 members (2-Ton, farmallb), 62 guests, and 4 robots.
Topics128,021
Posts1,055,352
Members48,420
#90257 01/11/2005 1:46 PM
In my not too well lit garage I can see a faint spark when I connect the positive terminal of the battery. Is this normal or do I have an electrical leak somewhere. If it's the latter I'm in real trouble because I have done so many things in the wiring I wouldn't know where to start. Your thoughts please.
Thanks, Don
#90258 01/11/2005 2:05 PM
Do you have any device that has a memory -- ECM or perhaps a radio? If not and the interior lighs are out then I would think you have an electrical drain. You might be able to make a swag by measuring the current draw -- though more than likely it will just be a case of elimenating circuits/devices one at a time.
#90259 01/11/2005 2:07 PM
If there is nothing connected, the ignition is not on, there should be no spark at all. You do have something that is drawing current.
1951 1 Ton Completed
#90260 01/11/2005 3:36 PM
Try pulling the fuses one by one to isolate the draw (Leak). Then go from there.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#90261 01/11/2005 9:27 PM
Anonymous
Unregistered
Anonymous
Unregistered
If you have an alternator, depending on how it's wired, you can get a slight current through the internal regulator when the engine is shut off. On a daily driver it's not a problem, but on a "toy" that might sit for months without being started, it can eventually drain the battery. I pull the plug on the alternator on my toys when they aren't in regular use(winter).
#90262 01/12/2005 1:42 AM
I put a diode on my ignition wire ... it stops the voltage from going back towards the ignition and eliminates engine "run-on" -- maybe that would do it?
See Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#90263 01/12/2005 2:18 AM
Thanks to all for their advice/suggestions. The truck has been re-wired and changed over to 12V with an alternator. Since I do not know how to verify whether or not it's the alternator causing the leakage I will pull fuses, one at a time and see if I come up with the solution. Alan, I have not checked your diode installation but will do so shortly and see if it's something I can do.
Thanks again, Don
#90264 01/12/2005 3:13 AM
Be aware that though popular the diode solution does have a down side.
There is about a 1/2-volt drop across the diode, and this means the alternator is not correctly reading the battery's charge.
As a result you could have some battery issues. I'd not expect it to be a problem if you don't drive the truck much. If you use the truck frequently I'd expect it to decrease battery life because the battery is always being over-charged.
