13 members (Bill Hanlon, Oldcaliforniakid, Southerntruck, D B Cooper, Peggy M, Jims46, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 2-Ton, 2 invisible),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Does anyone have a photo of the rear breaks? I think mine might be missing something related to the parking break in the rear break assembly. The cable is attached to the lever and the lever to the break shoe. I don't see how it will apply the breaks and mine does not seem to? A photo would be great or if someone knows if there is a part that fits into the knotch of the lever near the top eccentric bolt? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Have a look at this diagram. Brake Diagram Do you have parts 5.181 and 5.182? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Thank you. I don't have 5.184 or 5.182. Do you have any info on these parts? What does the arm connect to? The other shoe? I thought there were parts missing. Do you have any dimensions on the arm. I really appriciate the information. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So 5.181 is connected to a pivot at the top to the rear shoe and at the bottom to the parking brake cable. 5.182 is the spreader bar that goes between the shoes. 5.184 is the spring that goes on the pivot end of the bar and 5.158 is the pivot bolt. The pivot bolt has an eccentric that is used to adjust the setup. I think you need to get a used assembly to get all the parts. You could try on the Stovebolt here and also on Ebay. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Thank you for the help. I bought parts to make my own assembly but there is a wrecking yard near me "American Classics" that said they have 6 1/2 tons I can look at. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | GW, if you are still looking for those brake parts I may have them left over from a 4.11 to 3.55 conversion on my '36 Chevy pickup. To do that conversion I used both 1937 and a 1951 Chevy car rear ends. Tyhe parts may fit your 1/2 ton. My email is rwaldbaum at aol dot com.
Ray
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I am headed to San Diego this week. We will be stopping in Sacramento. Where are you located in Northern Calif. I grew up in Livermore. Thanks. | | | | | Joined: Mar 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 37 | do you think those parking brake parts would work for the 41 3/4 ton pickup? I'm searching for the right rear | | |
