0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#902247 12/09/2012 9:04 AM
I have 3 235 motors, one is a early low pressure motor, the other two are high pressure.
Since none of the motors are original to the truck they are in now, how can I tell what rebuild manual(s) to get or the rebuild specs?
Post the block casting number so we could determine the engine years.
Drew
Drew's suggestion is the only way.
high-pressure engine code locations
low-pressure engine code locations
Find and post the head and block casting codes, the head and block date casting codes, and engine serial number (it was called the engine identification code in some years - there was no engine serial number on 1957 and later 235/261 engines).
The block and head could be from different years. That is why it is a good idea to get all the codes and then get Shop Manuals for those years.
