1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#90206 09/21/2004 2:07 AM
Alright folks. I ordered a signal/hazard switch from Jim Carters, and I'm not happy with it at all. It’s silver and just attaches to your steering column. Anyway, I hooked it all up and it worked great, no problems, until I took the truck out for a short drive. When I got home and pulled into my driveway I turned the signal on and heard a pop, and a puff of smoke came out of the flasher body. I took the unit apart and found that the housing which I thought was metal is actually plastic. No big deal I don’t mind. Then I found that the wire attaching to the indicator bulb inside the housing had come off and shorted. I tried to reattach it by soldering it, but it happened again. I now realize that when you move the lever to turn, the wire gets bent and once you do it enough times the wire will simply break off.
Now I’m wondering where you folks get your signals from, and do you like 'em?
P.S. everything else I ordered from Jim Carters is great, no gripes there.
1948 3600 thriftmaster
#90207 09/21/2004 2:37 AM
Get a Signal-Stat 800 or a similar unit. They're on eBay all the time. A lot of them have been working for the past 40+ years. Wiring directions can be found in the tech section at www.oldgmctrucks.com
1954 GMC De Luxe COE
#90208 09/21/2004 2:40 PM
I just bought one of those shiny new ones myself. I took it apart and was quite alarmed to see the arrangement that you are talking about. I may take it back and I suspected that the wire would break. There is a whole science in designing wires and harnesses that flex and obviously it was not used here!
1951 1 Ton Completed
#90209 09/22/2004 12:31 AM
Junior Member
Junior Member
Yeah, the one I got from American Classic Truck Parts was pretty much a P.O.S. as well. Sometimes I have to wiggle the handle to get it to flash. Someday I'll get around to finding a better one. :rolleyes:
I can't drive 55... no really, I can't!
#90210 09/22/2004 4:24 AM
would a Signal-Stat 900 work as well? whats the difference?
#90211 09/22/2004 7:26 AM
I don't know a whole lot about them - I have an old SS 800 that is going in a project someday, and it looks quite well built. Is the 900 the 800 modified with a 4-way emergency flasher switch?
#90212 09/22/2004 10:38 PM
Riding in the Passing Lane
It must have 7 wires if you are useing stop
lights for turn signals. The 4 wire models
use seperate rear lights.
1972 Chevy c10 Cheyenne Super
