8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck),
87
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | Ok, here is the scoop: I have a 1948 3/4 ton thriftmaster. When I first got it, it idled, but ran very poorly at speed. It backfired, sputtered, and had loss of power. I drove it ~500 miles to bring it home, without a major problem. i figured out on the way home that if I partially choked the engine that it would smooth out the engine at speed, albeit at a gas milage cost. Now a week later, the truck will not idle without being partially choked and still has the same issues at speed.
After reading through various discussions here, I have narrowed it down to either the carb or the mechanical advance. The vacume advance seems like it works, if I turn the dist when running it will pull it back. At least vac advance shouldn't matter in a big way at this point. Here is a list of what I know or have checked:
- the engine was completely rebuilt (.60 over) less than 300 miles ago (before my 500 mile trip), but then sat for a couple years.
- the gas tank was pulled, cleaned and reset, ditto the lines.
- it has a new fuel pump and filter
- new air cleaner
- new plugs, wires, points, cap is new but has a couple chips in the base (suspect?)
- I pulled the plugs after my 500 mile trip with the engine partially choked, and they were very clean, just a light coating of carbon, which wiped off easily with a rag.
- it has a zenith carb from the origonal 216 on it (suspect #1)
I don't have a timing light yet, so I haven't checked the timing, but since the plus were clean and even on each cylinder, I tend to think timing isn't an issue. I have been wrong about timing before though.
here are some basic questions:
-it it worth rebuilding the Zenith carb, or was it never designed for an engine this size?
- If I were to replace the carb what should I look for that I won't have to modify the engine to put on? I'm looking for reliability.
Can you tell by looking at the mechanical advance if there is a problem with it?
Thanks for your advice/help. Aaron
I can't drive 55... no really, I can't!
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Look for a vacuum leak at the base of the carb or the intake manifold to head gasket.
#9019 06/21/2004 11:14 PM | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | Zenith makes an excellent carb; however one was never original on your truck. To determine if the carb is applicable for the 235, we would need to know the number on the Zenith tag.
As a general rule, too small a carb will run too rich up to a point, where it just won't run; too large a carb will run lean (need to add choke).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | Where is the carb tag? I looked and all I can find is embossed on the carb "Zenith Bendix" on the riser between the carb and manifold insulator it says 961.
| | | | | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | check that, I found a little round tag on top of the carb which has the numbers "11275" stamped on the top.
#9022 06/22/2004 12:50 PM | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | Rebuild the Zenith. If anything, it may be a tad large, not small. Would easily support a larger cam, head work, and improved exhaust if you have the desire to ever make these changes.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | Is there amodel number or something for that carb? I want to get a rebuild kit but don't know which one, or do all the Zenith kit have what I need? Aaron
#9024 06/22/2004 10:14 PM | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | The 11275 is the identification number. You can get a kit based on that number.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | Any good leads? Everywhere I have looked at Zenith kits, I don't see that number. when I do a search on google like: "zenith +(carb,carburetor) +11275" I get absolutely nothing. I did read somewhere that if the tag didn't have another set of numbers or letters on the tag that is is an aftermarket carb. Is this true? What carb would be original on a 61-62 235? Will that carb still work ok on a 235 .60 over? Thanks for all the help. Aaron BTW, I checked out This page :-) But couldn't find anything there that specifically listed my zenith carb.
