| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90192 03/30/2005 7:56 PM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | As I'm nosing around getting ready to do some rewiring repairs, I have found a fuse holder (PO installed) leading to the wipers and another just like it leading to the fan motor. Where the heck is my fuse box! Was that another option like the oil filter?
"Happiness equals reality minus expectations" - Tom Magliozzi
#90193 03/30/2005 9:03 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Mine is a Black box manufactured by Berg, it is plastic and has two screws holding the lid on. It mounted under the hood on the drivers side right above the front wheel | | |
#90194 03/30/2005 10:24 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ham - that ain't factory - the TF trucks had the factory installed fuse panel only if the truck had enuff electrical options to need it, tho' some plants installed it, some didn't - located on the interior firewall just above yer left foot - looks like this , and if ya can't find a used one, I think somea the suppliers have them repoped Bill | | |
#90195 03/30/2005 10:40 PM | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | I got the repo unit along with the $100.00 harness from Chevy Duty. Only minor hassles wiring the whole truck. I now have a place to wire a radio, heater, etc. BTY I put an alternator on when I did this. Originally the only fuse was the one in the headlight switch. The original wires were so bad many of the connectors were "burnt" or discolored anyway. I recommend changing all the wiring on an old truck. It's not hard and is lots safer.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#90196 03/30/2005 10:55 PM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | My truck is about as basic as you can get. No radio, no dome light no oil filter, nada. I suppose its total re-wire time. I'll check out Chevy Duty.
