Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, Peggy M, Southerntruck), 117 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#90192 03/30/2005 7:56 PM
As I'm nosing around getting ready to do some rewiring repairs, I have found a fuse holder (PO installed) leading to the wipers and another just like it leading to the fan motor. Where the heck is my fuse box! Was that another option like the oil filter?
"Happiness equals reality minus expectations" - Tom Magliozzi
#90193 03/30/2005 9:03 PM
Mine is a Black box manufactured by Berg, it is plastic and has two screws holding the lid on.
It mounted under the hood on the drivers side right above the front wheel
#90194 03/30/2005 10:24 PM
Ham - that ain't factory - the TF trucks had the factory installed fuse panel only if the truck had enuff electrical options to need it, tho' some plants installed it, some didn't - located on the interior firewall just above yer left foot - looks like this , and if ya can't find a used one, I think somea the suppliers have them repoped
#90195 03/30/2005 10:40 PM
I got the repo unit along with the $100.00 harness from Chevy Duty. Only minor hassles wiring the whole truck. I now have a place to wire a radio, heater, etc. BTY I put an alternator on when I did this.
Originally the only fuse was the one in the headlight switch. The original wires were so bad many of the connectors were "burnt" or discolored anyway. I recommend changing all the wiring on an old truck. It's not hard and is lots safer.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#90196 03/30/2005 10:55 PM
My truck is about as basic as you can get. No radio, no dome light no oil filter, nada. I suppose its total re-wire time. I'll check out Chevy Duty.
