1 members (Southerntruck),
73
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | I have a 235 out of a 58-62.
I know I have power to the coil. opposite of power in is a wire that runs to the side of the distributor. I have tried pulling a spark plug, grounding it, and get no spark. I have pulled the wire off the top of the coil, and set it near to see if a spark would jump, nothing happens.
This is my first take on a traditional coil and distributor system so I apologize for my ignorance.
Attached to the coil is a small cylinder, that I have been told is the condensor. It currently has no wires running to it. SHould it, and if it doesn't would that keep it from working. I may need to adjust the points, but it ran when it was parked 15 years ago, so i would think it would still be good.
Any help would be greatly appreciated.
1950 Chevy 3600
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You can get the help you need here. I might suggest to do a search on this site about getting a vehicle running after its been sitting for an extended period of time. The condenser of the side of the coil not being hooked up is not an issue for having spark or not. The points should be checked yes. Also check the fuel system and it may not be a bad idea to oil the cylinders and valve stems before you try and get it going. Good Luck Don | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Thanks Don.
I have been trolling the site for a while now, and I have appreciated all the help given.
I have ran new fuel lines, cleaned the carb, and the fuel pump works like a champ to my surprise.
Correct me if I am wrong. The points as they say is actually one point that can be adjusted by two srews. this one point then should drag along the hexagon shaped part below the rotor in the distributor. I assume the point gab should be set when the one point is on the flat side of the hexagon. If so what is that gap?
1950 Chevy 3600
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Also, like others have sugguested. I put marvel oil a tablespoon on top of the cylinders.
1950 Chevy 3600
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | WELCOME to StoveBolt, The points should be set when it's on the high side of the hexagon, or they will never close and it won't start.
__________________________________________________________________________________________________ Correct me if I am wrong. The points as they say is actually one point that can be adjusted by two srews. this one point then should drag along the hexagon shaped part below the rotor in the distributor. I assume the point gab should be set when the one point is on the flat side of the hexagon. If so what is that gap? [/quote] ___________________________________________________________________________________________________
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | When you say high side do you mean a corner of the hexagon?
1950 Chevy 3600
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Yes, and set the points at .019 inch.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Thanks guys. If I set the gap right, and there is still no spark what would the next step be.
Does anyone know a really good video showing how to set this gap?
1950 Chevy 3600
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I believe there are picture and a description of this in the shop manual. You can have a look online at Keith Hardy's site: http://chevy.oldcarmanualproject.comYou can use the 1950, or the later manual for your engine, in most ways, they are the same. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You can get it to spark by having the points closed (on the flat of the hexagon) and just open and close them with your fingernail with the ignition on. you should see a little spark at the points, and if you have someone hold the high voltage wire from the coil with the boot pulled back near the block, you should see a big spark.
A little care is required or the high voltage wire will bite ya. Just a little test to see if everything is working. You are of course bypassing the distributer cap when you do this.
Kurt | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the engine has not been run for 15 years I suspect the points have corrosion on them preventing them from making contact. Points are cheap. They can be cleaned but they most likely need to be replaced anyways.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I'm confused - did you say the condensor is attached to the coil?! Not in the distributor? I guess that might not make a difference, if it's on the negative post of the coil, but it seems goofy. Anyway, you sound like you've got the skills to lick this.
Are you able to turn the engine so the distributor shaft is turning? You are correct - there are two screws to adjust the points. Usually a smaller silver one locks the points, and a larger, brass one adjusts the base plate away from the arm to set the point gap. This is done with the arm right on one of the 6 peaks of the cam. You only need to slightly loosen the lock-down, adjust the gap to 19 thousanths, (don't freak out too much about getting this perfect - it would probably start anywhere between 15 and 25) and tighten the lock screw. You are adjusting how much the points open every time a cam peak opens the points, which should cause the coil to spit out the high-tension charge to the distributor center post, through the rotor, and out the right plug wire at the right time to fire the plug. And I agree with Dave, that it's likely the points are glazed over, and at least need some filing.
I also agree with Kurt - With the points on a flat, ie: closed, and with the ignition on, use a screw-driver or popsicle stick or something to flip the points open. You should get a regular spark every time you do this. You then know that the primary ignition is functioning well enough to run.
Now - with the distributor back together, and the center wire from the coil held close to a ground, if you don't see any spark when the engine is turned over, you either have a bad coil wire, or a bad coil. Be sure to clean the coil and distributor post, and the wire ends.
IF you get spark out of the coil, but not out of the plug wires, then again it's bad wires, or a bad rotor or cap. If the wires are stiff and crackle when you bend them, get a new set. The parts store should be able to set you up with a universal set for a six cylinder that will work fine, but try to get solid core wires, not that carbon-filiment-resistor wire crap that modern cars use.
OK - I'm now rambling. Good luck.
-MIchael | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Well Brad, does she run ?????
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Shes ALIVE!!!!!!!!!!! After replacing everything on the distributor new coil plugs and wires. Here we go! Heck yea! I should have bought the vac advance, cause that doesnt work.
1950 Chevy 3600
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 |
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | |
