Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (3B, TooMany2count, DaveV), 132 guests, and 6 robots.
Topics128,283
Posts1,058,513
Members48,490
#901624 12/06/2012 12:33 PM
Hi everyone, will a 1960 235 truck engine that came with a 2 speed aut trans bolt right up to my 55 second series pickup with a three speed trans without any modifications? Thanks in advance.
matt55 #901641 12/06/2012 1:21 PM
Shouldn't be any problem.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
matt55 #901647 12/06/2012 2:13 PM
chances are it has hydraulic lifters also.. !
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
matt55 #901649 12/06/2012 2:25 PM
1960-62 engines will not have the front side mounting provisions needed to mount in a 55 second.
My Blog
matt55 #901654 12/06/2012 2:38 PM
matt55,
Would you please post the engine ID that is pressed into the block just to the rear of where the distributor goes into the block? And, please post the (block date casting-code).
Also, please let us know at kind of lifters you have.
Most 235s with Powerglide transmissions had hydraulic lifters (as noted by DMGfifty); however, all other truck 235 engines had mechanical lifters. The 1960 truck specifications manual and Truck Data Book do not seem to be not clear about which style lifters were used in the 235/Powerglide truck combination. All 1958 and later 235/261 blocks were drilled for use with mechanical and hydraulic lifters.
matt55 #901665 12/06/2012 3:18 PM
Don't have the engine with me, a guy has it for sale on craigslist. I would buy it if it was a direct fit, but accirding to the responses im getting it looks like it wont be. Whst year engines should I look for for a direct fit?
I'm with Dave on this, the 552nd - 59 used brackets retained by 2 bolts on the side of the block behind the timing plate & long bolts/ spacers to frame. Not bolted to timing plate.
BC
1960 C60 pasture art
matt55 #901676 12/06/2012 4:16 PM
If your truck was originally a V8 the radiator is mounted further back and a 6 won't clear it.
matt55 #901686 12/06/2012 4:50 PM
As BC said, 1955-59 pass or truck (except 55 1st truck) will fit.
My Blog
matt55 #901700 12/06/2012 6:07 PM
Thanks for the info guys, I appreciate it.
matt55 #901862 12/07/2012 11:23 AM
"1960-62 engines will not have the front side mounting provisions"
..that is correct. I had forgotten about the engine mount change. I was only thinking about the AT fitting it. However the front mount can be installed on a 60 engine so it can still be used w/o major difficulty.
Dave
matt55 #902485 12/10/2012 4:58 AM
I bought the same motor as you and it does not have the mounting holes for the bird legs side mounts but after looking at it I think I can use the front mount and just install it on the cross member. If anyone has done this can you please advise? If I get it to work on mine I will let you know.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
