8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Hi everyone, will a 1960 235 truck engine that came with a 2 speed aut trans bolt right up to my 55 second series pickup with a three speed trans without any modifications? Thanks in advance. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Shouldn't be any problem. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | chances are it has hydraulic lifters also.. ! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1960-62 engines will not have the front side mounting provisions needed to mount in a 55 second.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | matt55, Would you please post the engine ID that is pressed into the block just to the rear of where the distributor goes into the block? And, please post the ( block date casting-code). Also, please let us know at kind of lifters you have. Most 235s with Powerglide transmissions had hydraulic lifters (as noted by DMGfifty); however, all other truck 235 engines had mechanical lifters. The 1960 truck specifications manual and Truck Data Book do not seem to be not clear about which style lifters were used in the 235/Powerglide truck combination. All 1958 and later 235/261 blocks were drilled for use with mechanical and hydraulic lifters. Thanks, | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Don't have the engine with me, a guy has it for sale on craigslist. I would buy it if it was a direct fit, but accirding to the responses im getting it looks like it wont be. Whst year engines should I look for for a direct fit? | | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | I'm with Dave on this, the 552nd - 59 used brackets retained by 2 bolts on the side of the block behind the timing plate & long bolts/ spacers to frame. Not bolted to timing plate.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If your truck was originally a V8 the radiator is mounted further back and a 6 won't clear it. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As BC said, 1955-59 pass or truck (except 55 1st truck) will fit.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Thanks for the info guys, I appreciate it. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "1960-62 engines will not have the front side mounting provisions"
..that is correct. I had forgotten about the engine mount change. I was only thinking about the AT fitting it. However the front mount can be installed on a 60 engine so it can still be used w/o major difficulty. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I bought the same motor as you and it does not have the mounting holes for the bird legs side mounts but after looking at it I think I can use the front mount and just install it on the cross member. If anyone has done this can you please advise? If I get it to work on mine I will let you know.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
