1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
How hard is it to stop a 46 Chevy 3/4 ton with manual brakes. Because I haven't been able to find a brake booster setup that will fit all the ones I have found are for 1/2 tons. I am swapping the rear ends out. Putting a 14 bolt out of a 81 Chevrolet 3/4 ton with a 3.73 gear ratio so I can go faster than 45mph.
The manual drum brakes on my '56 are barely adequate at higher speeds. They stop me OK but it takes a lot farther to do it than with my Suburban with power front discs.
Seems like someone on here has built a bracket for dual cylinder in 3/4 tons. I'm sure they'll be along shortly.
Crusing in the Passing Lane
Doesn't matter if for half ton or 3/4, just so it fits in the truck. Disc brake kits are available for your front, 80's Corvette MC for front disc/rear drum setup(factory) are a good MC to use; or just use a MC for a drum/drum setup.
chevs of the 40's sells the disc brake conversion kit
My '41 3/4 ton stops just fine with the original brakes. I can lock the wheels if I need to.
I suppose the brakes would fade a bit if I were racing it, but I don't. It also takes a bit more foot pressure that my 2010 Ranger.
Don't forget the brakes were designed to stop the truck under full load, I don't do that either.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
