3 members (TooMany2count, 32Fordpuchoptop, Hotrod Lincoln), 92 guests, and 3 robots.
Topics128,141
Posts1,056,485
Members48,441
I've removed an ignition switch from a cylinder, but how do you re-install it? Thanks
Even if you have a manual the manual tells us 'What' to do not 'How' to do it.
When taking something apart for the first time its a good idea to video or at least snap pic's of the dis-assembly sequence so you have something to refer to when your try and put it back together...
years brands and model #'s help those who take the time to help you find the specific answer your looking for and invite more helpful answers than this one ohwell
Give me ambiguity
or give me something else
the body of the item is the 'ignition switch', the part that you've removed is the 'lock cylinder' .... just push it back in the hole in the same orientation as you pulled it out, if you haven't messed anything up it just seats itself in
...click...
install the key first
Nice video!!
