7 members (Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series),
74
7
Mod | | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | any one have a pic of the rear of a 36 suburban without the bumper mine was missing the panel below the door and i need to see what it looks like so i can fab one thanks | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | You might find some pictures here: 1936 Suburban build or contact mtvoices | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Leonard.. I'm restoring my 36 suburban, it has the clamshell doors as it;s a very early 36.made nov of 35. I will go over to the garage tomorrow..and tske some shots of the rear doors without the bumper..the metal under them is pretty simple with a slight curve to it. Are you going stock on yours? Where did it come from? Mine was in a mass. barn for forty five years! All seats and everything was intact...very lucky to have found it. We'll be fnished in March..next yr. Bruce D. (mtvoices) | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | all i got with mine is the sheet metal and frame it has all the windows and dash so i am going to do a restorod will look like a suburban but with late running gear and power windows and newer interior replacing all the wood with metal | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Leonard I have pictures of 36 Burb rear plate,email me: so I can [email protected]. good luck, it should be an easy make on this piece. thanks..Bruce D. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Leonard haven't heard from you..send me your email..at [email protected] pics of the rear lower area for you....bruce...mtvoices | | |
