0 members (),
89
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'm replacing the temperature gauge sending unit on my truck. I don't want to use teflon plumber's tape. It doesn't hold up to the ethylene glycol in the antifreeze. Or could split off and clog something.
Is there a good sealant to use on the threads?
Thanks. Mark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you must not use anything on the threads of an electrical sender or you will not get a good ground to make the gauge function - the taper of the threads makes the seal
Bill | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | That makes perfect sense. It probably would read cooler than it really is if there was something impeding the unit. Thanks Bill. | | |
