0 members (), 67 guests, and 5 robots.
Topics128,271
Posts1,058,313
Members48,485
#901189 12/04/2012 3:57 PM
I'm replacing the temperature gauge sending unit on my truck. I don't want to use teflon plumber's tape. It doesn't hold up to the ethylene glycol in the antifreeze. Or could split off and clog something.
Is there a good sealant to use on the threads?
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #901195 12/04/2012 4:23 PM
you must not use anything on the threads of an electrical sender or you will not get a good ground to make the gauge function - the taper of the threads makes the seal
MarkT #901206 12/04/2012 4:51 PM
That makes perfect sense. It probably would read cooler than it really is if there was something impeding the unit. Thanks Bill.
