5 members (Shaffer's1950, Wayne67vert, Hotrod Lincoln, ‘37ChevyPU, Hanks custodian), 130 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
#900877 12/03/2012 12:06 PM
I am updating my stock 3/4 ton front axle with a lowered 1/2 ton axle by SID.
The stock ball joints are shot and seized.
pictures
Wht is my best and most painless upgrade for the tie rod and drag link?
Mike
Click the link to see my truck.
http://smu.gs/OuBwfv
Since its a 1/2 ton you can use these at the bottom of page or here for new ends and drag link
Multiple vendors sell the parts. You can check the Vendor links for more options.
Good luck.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
I bought the whole 3"in drop axle kit kit from sid's with the tie rod tie rod ends, steering arm,and draglink, i had to bend the steering arm a little bit so the steering arm would clear the axle, but it all went together pretty easy,
american classic is about the cheapest place to get those parts, I built most of my 46 1/2ton with american classic truck parts,
