| | | Forums66 Topics128,136 Posts1,056,431 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I have a 1949 3600 and I am putting a 5.3 Ls fuel injection motor in it. Wanted to use a Mustang 2 front end. Has anyone done this swap and if so any pics would be great. The New Guy | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There are plenty of these trucks running mustang II. You're better off to search another forum if you're looking for a specific build thread, but there are probably a couple here too. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Done thousands of times. Use the search feature of the site and you should find a wealth of information to help in your project. Good luck.
| | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I see that it is done alot but no one can tell me if the IFS front end for a 1/2 ton will fit a 3/4 truck. Not sure if I should go with a universal kit or if someone could tell me the diamentions of the one listed. Just really trying to find someone that has put a IFS on a original fram (not S10). Thanks in Advance | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The 3100 and 3600 frame/suspension are pretty much identical from the cab on forward. The only real difference is that the 3600 has a different axle. Any IFS kit for a 1/2 ton will work on a 3/4 ton. | | |
