| | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | Does anyone know if the frame dimension is the same for a IFS on a 3600 and a 1/2 ton truck. | | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | To my knowledge the chassis is the same in the front. I know axles swap between the two, so the leaf spring width must be the same. Who are you getting the IFS from? They should know. Wonder over to: http://talk.classicparts.com/forumdisplay.php?f=7 | | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I am getting my IFS hopefully from Heidts. I called Speedway and they could not asure me the measurements are the same. I will call Heidts and deal with them directly. I alread mounted the motor mounts and transmission cross member. | | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I am using 5.3 alum. block motor with a mild Comp. cam. and a 4L60E trans. | | |
