4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#901065 12/03/2012 11:34 PM
Does anyone know if the frame dimension is the same for a IFS on a 3600 and a 1/2 ton truck.
James1975 #901126 12/04/2012 10:05 AM
To my knowledge the chassis is the same in the front. I know axles swap between the two, so the leaf spring width must be the same.
Who are you getting the IFS from? They should know.
Wonder over to:
http://talk.classicparts.com/forumdisplay.php?f=7
Click the link to see my truck.
http://smu.gs/OuBwfv
James1975 #901380 12/05/2012 10:39 AM
I am getting my IFS hopefully from Heidts. I called Speedway and they could not asure me the measurements are the same. I will call Heidts and deal with them directly. I alread mounted the motor mounts and transmission cross member.
James1975 #901381 12/05/2012 10:41 AM
I am using 5.3 alum. block motor with a mild Comp. cam. and a 4L60E trans.
