1 members (Woodcmiami), 86 guests, and 4 robots.
Topics128,100
Posts1,056,513
Members48,448
Is there such a thing? I think I have one. It has a pipe that attaches to a plate on the manifold.
Any info on it?
Dennis
Yes, there is such a thing that was used on passenger cars and on Hydra-Matic equipped Chevrolet trucks.
Maybe someone knows when/if that heat pipe/stove automatic choke was used on any manual transmission late 50s or early 60s Chevrolet trucks.
What size/year is your engine?
What is the engine serial number code?
Thanks Tim. I pulled the carburetor off a truck at a salvage yard years ago. I forgot about it and noticed it yesterday when cleaning up.
I have a later 235 to put in my 48 and am trying to decide if I should stay with either the manual or auto choke Rochester carb or rebuild and use a carter ys2100 that I picked up at a swap meet. Don't know?
Dennis
Is it a Carter YF 2100S? (you had typed ys?) anyway great carb, and also manual choke. I have one on my 235 and love it.
Kurt
Love my Carter carb. Ethanol was eating up my Rochester seals and I had constant vacuum leaks at the throttle valve...put on the Carter 2 years ago and it has been bullet proof.
1950 Chevy 3600
Instagram/Olbluechevytruck
on Classic trucks:
http://rides.classictrucks.com/ride/1085750/olblue/1950/chevrolet/c20/
Thanks guys. Kurt you are right. Bad typing.
Sounds like I should go with the carter.
Dennis
No reason why the auto choke carb won't work as well. You will need the correct choke stove plate to get heat to the carb. My friend has a 56 car with a stick shift that uses one. It was factory. The Carter carb is always a good choice.
Fred
When I picked the carb I also got the tube and plate.
Thanks Fred
Dennis
