1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#900857 12/03/2012 9:47 AM
Sorry I took so long to get back, My Signal Stat 900's polet light won't disingage.New 535 flasher, bulbs, and new wiring. Just "happened."....Someone make my B'day, Paul
any luck on your pilot light?
red 53 pickup -
Assuming that you have the wiring correctly connected to a three prong flasher ... Have you taken the unit apart? The pilot light bulb moves with the "directional signal operator" (the lever). The bulb socket may have popped out of the holder, or other parts inside the 900 case may be out of place. Don't lose the wavy washer (part #69) shown in the two patents that I linked below. Dab a little grease on the moving/sliding parts.
I haven't had my Signal Stat 900 apart for a while, so I can't give you exact info. However, drawings of the units are included in the patents for the devices.
Here are links to to some drawings:
> Pat #2886743 May 12, 1959 (this is the 900 that is in my truck)
> Pat #2812396 Nov. 5, 1957
To find the patent, Google the word "patent" followed by a space then the patent number. Then choose the link that includes the name of the patent holder ... Jesse R. Hollins.
> My Signal Stat 900
> Pat Nos on my 900
- Lonnie
My '54 3104
