0 members (),
150
0
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | My '50 Chevy with a transplanted 235 starts & runs perfectly...
However, if I make a stop and try to restart, it usually won't. If I let it sit for 5-10 minutes, it'll start right up.
Any thoughts on causation?
Note: I am not flooding it, and I don't the carb is vapor locked...hmmm
Thanks - Dickson
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Does it crank fine but not start or is it slow to crank over?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | It cranks fine, but just does not like to start when recently run...Strange. Thanks!
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | What size are your battery cables? Do you run 6V? If so you need the 00/0 size cables.....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When my 216 is warm and left for a few minutes, I put the gas pedal to the floor, hold it there for about a minute and then hit the starter, with the gas still to the floor. I find this works well. | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Thanks Sweet & truckernix.
1. It is a 6V truck, so I'll upgrade to 2/0 cables 2. I'll try you're "hold it to the floor" trick next time.
Thanks! Dickson
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I'll bet it's a carb issue... | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I would also clean and tighten the connections at the starter switch, coil, distributor and ground strap.
Kurt | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Sometimes they like to be cranked over a few revolutions to clear out a possible rich mixture, then a little tap of the gas. When the carb gets hot (sits for a few minutes), they will percolate fuel into the manifold sometimes. Just the charm of an old truck!
| | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | Years ago, we always thought it was the coil going bad. It might be something else, but you should probably consider it. | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Thanks guys. No major disaster. At age 45 I'm just learning patience...so I'll just try to be patient and wait the extra 5 to 10 minutes she takes. Like an old woman, she just wants me to know who's really in charge!
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Mr. Lang has it correct. The carburetors will percolate after you shut the engine down which floods the engine. Right after you kill the motor or after they sit for 15 or 20 minutes they usually start right up, but its that period inbetween that is disappointing. And as Ken instructed, holding the throttle wide open while cranking it will clear the access fuel. Make sure there is an insulator between the carb and manifold, it helps a little bit. Occasionally someone will replace the carb with out the insulatore which adds to the problem. Denny Graham Somewhere north of Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Still flumoxed...
Today a buddy and I replaced the coil, regapped the points, checked the firing order and timing, and confirmed spark.
Still, no fire. We are still just pouring a little gas into the carb to start her. Should work. Stumped! Dickson
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you have to prime it to start it, it is not flooded. Are you sure the accelerator pump is squirting?
