Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (1955 1 Series, 3B, Jay R, Wayne67vert, Phak1, DaveV, Hush), 123 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#900756 12/02/2012 8:54 PM
Hi Guys: is there any outside physical way i can tell if my 54 engine is a 261 beside the serial numbers????
billm #900758 12/02/2012 8:59 PM
billm #900759 12/02/2012 8:59 PM
Leo Offline
Moderator
Moderator
My 261 has 2 "captain's bars", 2 raised parallel lines or bars cast into the side of the block above the starter, almost a dead give-away for a 261.
billm #900761 12/02/2012 9:03 PM
Leo Offline
Moderator
Moderator
You can also check out the tech tips on how to identify your 216, 235 and 261.
billm #900772 12/02/2012 9:17 PM
Thanks...it is pitch dark here so I will look in the morning. Thanks again for both your help!!
Leo #900782 12/02/2012 9:38 PM
"Almost" is the important word. All factory installed 261's should have the Captain's bars, but 1953 Power Glide full pressure 235's also had the same Captain's bars, so check casting date also.
My Blog
Pre '68 Dave #900824 12/02/2012 11:39 PM
I just bought an engine I thought was a 261. Code LAQ 373718. Has the bars. Seems to be a '53 235. It does have the short water pump & 848 head with 216 valve cover. And the side motor mounts aren't the typical V shape. Two on top & one directly below a top one.
billm #900826 12/02/2012 11:50 PM
My early 261 does NOT have the captains bars
Josh
billm #900838 12/03/2012 2:13 AM
There are some 261's reported to be missing Captains bars, but I think they are replacement engines or maybe from Canada or...
My Blog
49Neo #900839 12/03/2012 2:16 AM
Sounds like a 1953 Power Glide full pressure engine to me. That is a good engine even if it is not a 261.
My Blog
billm #900842 12/03/2012 6:18 AM
As Dave posted above, the LAQ engine serial number prefix designates 1953 235 used on a series 2100-2400 car with a Powerglide transmission. The "captain bars" have been previously reported on these 235 blocks.
The block and head casting codes and casting dates are the most useful information when trying to ID these blocks/heads.
Pre '68 Dave #900964 12/03/2012 6:57 PM
Leo Offline
Moderator
Moderator
Dave, my 261 is a Canadian Pontiac engine, has the captain's bars and I've seen more here with them.
billm #901015 12/03/2012 9:34 PM
And my '53 235 Powerglide engine also has the captains bars.
Kurt
